Tuning out egr?
Timing
So i need to go get a sticker and i need to make it so 1 i can still have my wideband hooked up threw the egr plug and 2 so the readyness test will pass. What do i need to do to the codes exactly in hpt? I have to have egr enabled to use the wideband threw it so is there a way to make the codes not show without turning off egr?
I "read" once that you could:
Set 'all' the codes to no report as the drive cycle test will then be completed and you'll test just fine.
hypothetically of course... As I don't believe it is technically ok to do this.
:D
you have to delete a lot of codes to do that lol
egr is like 3 codes you delete. aka set to no report. then in dhp is another folder with the same codes, you set the values to 0 next to the same codes.
at least in dhp, no clue how htp works.
The voltage will still be there, setting it to no report/and or setting egr temp to max just means it won't set off the check engine light.
