tuning for gears.
Merlin
I am having a brain fart on changing the tables for 3.29 gears. I am looking at the tables and i cant seem to make out exactly how i change the spedo table to see the new 3.29 gears. I see the final gear ratio is already 3.29.
Should I go ahead and swap all the data over from a gt file to get this to work or do i just put 3.29 into the new final ratio box and hit commit.
Im used to the rwd tables, so sorry for my stupidity.
All you need to do is change the FDR ratio to the following for the following gears. THAT IS IT.
Current gears installed / FDR
2.93 / 3.29
3.29 / 3.69
So you would simply enter 3.69 for your FDR ratio. That is the simplist and best way of doing it.
I swapped a PCM from a 2005 GP GT and when u start out at low speeds the tranny acts like its in limp mode or it surges in power. What do i need to change
