Travisgt2 Phoenix
Travisgt2
As many of you know I have had some unfortunate luck with my first 04 GT2 I have now picked up a second 2004 GT same color and ptting my motor in it so as the old car has crashed and burned so to speak a new 2004 GT2 will rise from it with new ideas a whole lot more crazy sh!t.
Taking good motor out of old car
Taking blown motor out of good car
Rebuilding the motor with it's new stage 1 cam
Freshly rebuilt motor in New car
Just traded one my three na lim and uim for a 3"down pipe.
Built my heads this morning did new valve seals, 90# ls6 springs, new spring retainers and locks. Everything is here all my gaskets for the motor and my special bolts I had to order to get the harmonic balancer off.
Subbed, you still going to turbo? I think you and I are the only ones in this site who has a n/a built lol.
If I can beat my brothers Acura and the others 02 gs then I'll stay na for awhile I plane to be very very thorough when building my turbo build like two years thorough
Ya I don't think I'll ever go turbo, when this car rots outs I'll get a 04-05 impala SS, or a 05+ gtp and threw the 3.69 trans in it with the rest of my mods and pulley down to a 3.6
Pulled the harmonic balancer off and got front cover off to get cam out. Replaced oil pan gasket and looked at everything it all looks good.
My younger brother has an 02 regal gs no mods and the one younger then him has a 04 Acura TL. I want to try beat them all motor. If not turbo time! And i don't think i want to race at all blue lol. I'm going to run reptiles tune on the gt1 cam think I'll be okay with that?
Last year before my gears, er rockers, l67hvtb,I beat a regal GS, so you shouldn't have a issue. Not by much I was slowly creeping by lol
Other motor comes out today got a three inch down pipe! Carpet is out of old and new glass vacuumed up (safety glass is a bicth) head liner switched over wire's run for amp and sub. Cam is in upgraded rollmaster is in timing cover goes on today
Cars together was run through its break in process like comp cam said to changed oil and filter. Got loaded on a dolly and taken to kck to my new house. Drove it today brakes seam soft but damn it's fun to drive.
Still needs done
Interior in
Getting radio and sub hooked up
Find exhaust rattle
Finish getting the lower lip on the front on
And I'm buying my brothers gs he just got a dodge avenger thinks it's faster then his gs and my car
It probably is, there's no break in process its not a full rebuild you just swapped cams and a few other things either you did it right or you didn't
Sent from my KYOCERA-C6745 using Tapatalk
