Transmission problems yet no codes
kozy
Last week, my car stopped going into 4th gear and started to not want to shift into new gears as I'm accelerating. This all coincided with my TPS taking a ****, as was evident by the P0122 code. Tested all the wires and the TPS, determined that the wires were good but the unit was bad so I replaced it with a junkyard unit I got for $5. Had the codes deleted and the CEL hasn't come back on yet.
The 4th gear issue I understand is that the spline have been stripped. I can't figure out why the transmission is still not wanting to shift as I accelerate (only once the transmission is nicely warmed up). The car isn't throwing any trans codes at all. Could the solenoids be going bad just not quite enough to throw a code yet?
