So lets start this off. I have a few issues I'd like to discuss.
1. My RPMS jump up and down while I drive on the highway and put a load on the engine ( I believe after reading Triple Edges web site that its the TCC valve)
2. When my transmission shifts into 3rd under very light throttle is goes very quickly, because of this it like chugs a little.
3. I get a vibration on the highway SOME TIMES. It can get better or worse. Things I've eliminated are, wheel bearings (had one replaced other is fine), control arm bushings (replaced a little while ago), rotated tires, axles are fine (drive side was replaced as boot tore)
I want to just make sure its going to last as I don't want to blow the trans up. I installed a ZZP shift kit (I regret getting it as its a waste of money, I will buy an intense shift kit and replace it.....maybe the issue with 3rd shifting to quickly?) and changed over to Dex 6 fluid.
