Hello to all, I have a 2000 Pontiac Grand Prix 3.8l w/ a 4T65E transmission that has about 82k miles on it. I will be installing an Imperial Transmission Cooler and need some reassurance on a couple things...
1) Is the transmission supply line run into the bottom of the radiator & the transmission return line coming from the top of the radiator back to the transmission??
2) Should the transmission cooler be installed in series with the factory cooling or should the cooler be installed as a stand alone transmission cooler?? (I live in upstate NY which winter temps can get as low as 20 to 30 below)
3) If installing the transmission cooler in series, what would be the appropriate routing of the complete trans cooling set up.....Should it go like this?? Transmission supply line>bottom of radiator>top of radiator>bottom of external trans cooler>top of external trans cooler>transmission return line ??
4) Should I use the stock clamps that came with the trans cooling kit or use a better alternative on all connections??
I appreciate any and all feedback on all 4 questions, Thanks ahead of time!!
