Transmission axle shaft??? maybe called output shaft.
tommygunz12
so i am doing the solenoids on a 2006 grand prix 3.8 sc 4t65e-hd tranny. i have the side case open and i noticed that the shaft that connect to the c/v axle has some play in it.... it this ok or something else really wrong?
Sloppy is normal in these transmissions. You should see the parts behind the case cover aka channel plate before the 4th thingee goes in place. Sloppy mess
