trans
only the 97 GT trans is vac controlled
Yep, thats a pretty big mistake on my part, was very hungover this morning/afternoon.
The differences from the 97 gtp to 99 gtp are very small. If you were to rebuild the 97 the diff's are a bit different as well as the output shaft, but as far as a straight swap it should work.
^^ this last one is on the money. The diff/output shaft has a C clip holding them together instead of a compression clip. The valve body etc isn't the same material either, but that's small.
Swapping wise...they should be considered the same.
