Well, I've had some issues with my trans. for a while now with erratic line pressure and converter flutter/slow lockup. Non of these conditions exist though when trans is cold but start to show when the trans get hotter.
I'm running a external cooler, trans go shift kit on 2, and the pcm line pressure is jacked way up. I have the DHP tuner so I have no converter duty cycle access. Trans. only has 28,000 on it and the converter is brand new from GM. Just today, I installed the TAC adaptor to see if this would help and it did for the most part but I'm still seeing some issues when it gets hot. Still get a little converter flutter(very small now). Funny part is the original trans exhibited some of the same issues, only difference is the cluches were toast by the time i got the car. Anyone have an ideas??
