JJ91284
I want your input on a few possible mods to the 4t65e
I saw these mods on a peformance build 4t65e DVD
3-4 accumulator
Taking apart the 3-4 accumulator cylinder and putting a washer on the bottom of it. So it would be Washer,spring,spring,piston,piston pin. He mentions putting the assembled unit into the channel plate and loctite the piston accumulator assembly into the channel plate and hold it into place with a c-clamp until it dries.
Sonnax Sure Cure Kit
Recommends Enlarging TCC 9b to .030 because it is to small and can become plugged.
Seperator Plate Recommendations
ATSG blue book numbered for Reference
25/27 hole (smaller top hole) drill to .086
31/29 hole (smaller one on bottom) drill to .096
29 (smaller top hole) drill to .086
2/4 drill to .031
I know the ATSG Green Book says not to go over certain sizes, and these almost are all over their maximum value. I'll post a pic of the ATSG Green book spacer plate tomorrow
He also mentioned scuffing up the outside of the 1-2 Roller Clutch. He mentioned if its glazed, you might be better off getting a new one. He said something about scuffing up the exterior side of the 1-2 roller where it meets the forward band. Is this suppose to give the bad a bit more grip and prevent it from slipping?
I'll probably post more questions later, but I just skimmed through the dvd and didn't have a whole lot of time.
3-4 accumulator
2/4 drill to .031
