tazgtp
Well I got my tranny replace not rebuild like I wanted. The mechanic said that he replace it with the same year and make. I towed it home and decided to drive it later that day. It shifts so hard that it causes the cd player to skip. And it shifts hard in every gear. The torque converter doesn't lock up. WOT it shifts very smoothly and downshift are smooth also. I hook up my scanner and po730 came up. By the way I have a 01 GTP with 175K miles. Where is the part number on the transmission so I can look it up the see what tranny it is? And if it is the right tranny what can I do to get rid of this code? The scanner I have is a Snap-On Solus Pro. It can do alot of stuff. I'm taking it back on Monday and telling them to fix it. But if I can fix it, it would be great. Any suggestions would be greatly appreciate.
Thank you
Rent
Thank you
Rent
