Tranny service.
GTP 40TH
Done today. Boy was the fluid dark. Re-used original pan gasket. Took almost seven qts of fluid to refill. I feel better with this done.
Just about there.
check the fluid again after you've driven.
Agreed. I usually check the fluid 2-3 times the day I do the pan drop. Then once a day afterwards for a week. Then once a week for the next month or so. Most of time I will have to add a slight bit more fluid along the way.
