tranny making noise
bbptech
I am having a few probs. first off its a fully rebuilt tranny.
ZZP Parts: 3.29s, 2500 stall, 4340 input, oil pump shaft, output shaft, 4th clutch shaft, shift kit, GM overhaul kit.
thats what i brought into the transmission shop. They replaced alotta other things that were worn out as well. Valve bodies and other things i dont remember. Tranny originally had 193,XXX miles on it before rebuild.
Got it on the road finally and heard a noise. I did almost everything to rule out the noise. Motor is fully rebuilt as well by the way. I had a P1374 code so i replaced the Crankshaft position sensor. while driving down the road when i let off the gas right away my rpms drop to bout 900 rpms. It definetly sounds like the transmission to me. But i just dont know what might be causing the noise im hearing. The noise is noticeable at around 2500 rpms and up. Im pretty sure its not a lifter(s) because i know i set preload properly before i put the motor back in.
Im just at a loss. i dont know what to do anymore.
you shouldnt have to deal with these issues any more and should just give me your car...
does it only make the noise while your driving
At what speeds
straight line or turning
