Robby Avery
Just as title implies what is the interval the trans should be flushed? I did a search on here but no results. Thanks in advance
Well I might try the pan drop method first. I have two trans codes that I need to get fixed they are P0420, and P0742. I posted in another thread I was told they are trans related. I'm guessing the trans fluid is possibly black don't know when it was last changed as its a used car and my GF had long before I met her.
My advice would be to put in fresh AC Delco spark plugs, fresh spark plug wires, fresh fuel filter, clean the mass air flow sensor with MAF cleaner, clean the throttlebody with throttlebody cleaner, and replace the catalytic converter (remove the "U-bend" in the exhaust while you're at it). A trans flush to GM spec would be good as well.
Then see where you're at.
P0420 = Bad/leaky catalytic converter or oxygen sensors, or even bad wiring to the sensors. It has absolutely nothing to do with your transmission.
Usually, this it s a clogged cat, which will break all kinds of other things - I'd start here and see if it fixes your other issues.
p0300 could be fuel contamination or clogged injectors. Maybe bad spark plugs.
I'll let the TrannyMan handle the rest:
P1811
P0742
Man if I had a nickel for everyone who has went though this cycle. Do no maintenance, break the car, and only attempt to do the very least in a vain attempt to fix it.:th_shakinghead2:
I feel for ya, I went through the same thing with my X abusing her car.
Good luck, but I wouldn't expect aynthing to be fixxed with fluid at this point.
Harsh shifts, P0742
P1811
P0742
How would I go about deleting the u bend does someone make a kit? I looked at zz performance but no luck. Again thanks to all who have helped me thus far in this thread.
Ok guys I checked the trans fluid today and its still red with a slight dark tint to it. I can see through it but its a little darker than brand new ATF so where do I go from here? Should I change it since its well north of the 50k mark intervals the car has 130,***mi.
u-bend delete is simple, remove o2 sensor, remove bent piece of pipe, insert straight piece of pipe. keep in mind it'll throw a code/SES light because of not having a rear o2 sensor. you can either ignore it, set it to "no response" or something in the pcm, or build an emulator, which ive read is pretty easy too. something about a resistor... i don't remember
