traction control active
papaspanky
Ok here goes I have had my 06 GPGT for a few months now and have had an annoying problem in the front end when backing with the wheels turned to the left it feels like the front left tire is rubbing on the wheel well. I had chalked the tire and discovered it is not rubbing. the other night when parked in the lot at work I turned the wheel left and felt the rubbing and traction control active came up on my dic. could it be a bad speed sensor? it does not do it when I turn right.
well when you first start the car and reach i believe 5mph the abs/traction system does a check that can be slightly felt in the car, i wonder if something is wrong with the test
My 04 does the same thing. It must be a bad wheel speed sensor or bad hub, either way it's a easy fix and I still have to fix mine.
