Traction and brake light still on after replacing wheel bearing
Kadeas
The wires were ripped from the front passenger side wheel bearing for the ABS sensor somehow. So both lights were on on the dash. I bought a new wheel bearing a cheap one off of Amazon, and put it on and the lights went out but when I put the car in gear and start to drive the lights come right back on. The TC button works until the lights come on you can turn the traction control on and off to the point where the lights come on and it doesn't do anything. This is in a 2004 Comp G. Thanks for your help
Check the body harness that plugs into the hub. Lot of times they get corrosion in the plug end that connects to the hub and even further up into the wiring.
