Currently having a misfire/stuttering issue at the following areas ONLY:
Between the 4000-5900hz with converter locked and TPS around 25-30% (converter unlocks at 30% and above)
I sprayed the MAF cleaner and no change
I currently have P0300 turned off cause of my VS cam
Runs fine in boost
last resort would be to turn the P0300 back on to see what cylinder’s misfiring, if at all but was curious if anyone would be able to know right off the bat the issue. My thoughts are the following:
plug wires has some miles on them but can’t recall how much, maybe 50k miles?
Plugs are AL103 gapped at 0.050 and has maybe around 6-7k miles
ICM
Voltage’s around 14.6
Runs fine in boost
ICM
