TPMS/Remote
briandurr
When I push the lock and unlock button on remote together, TPMS will not go to relearn procedure. none of the buttons work on either remotes(batteries are new in both), I havae had Tech2 scanner hooked upto manually relearn TPMS t will not go into relearn. Drivers door does lock and unlock all the doors with the button on the door itself. Someone tyold me there was a door lock transmitter in the right rear back window deck???? Is this correct? Is there any interchangeable years to replace with a used one if it is in rear window?
Like I said in chat what kind of car is this? The door locks on 97-03 gps are controlled by the bcm, its in the dash behind the radio someplace. And I am not sure where it is on 04+ cars.
04-05 don't use TPMS they use wheel rotation and is part of the aaa as system. The receiver for 04+ is between the rear deck and sheet metal of the rear deck in the center.
Jeff
