Topswapped gt overheating issue
suitercrew
Hey guys i have a topswapped gt that runs great but i live in arizona have a 180 degree thermostat and am tuned for it. But during summer heat my temps have been getting up to the very top of the temp gauge right before red. Im wondering if this is normal or if maybe i need to upgrade from the stock gt radiator to a 1 inch gtp raidiator.
Sent from my LG-H811 using Tapatalk
check your temps via the obd port, the dash gauge is not all that accurate.
as long as the fans are on you should be ok still.
im running a na rad in my gs. its bottom swapped. my temps are the same as with the old rad. and i still run a 195 t stat.
I have the stock gt radiator in my car and a 180° thermostat temperature stayed the same after the topswap
Sent from my SM-G920V using Tapatalk
