Top Swapped Pulley drop VS L67 Pulley Drop
BoostedPontiac
Regal GS Level Member
All i really want to know is how much of a difference a 3.4 is on a 8.5 (L67) compression block vs a 9.4 compression block (L36).
Would running a 3.4 on the top swap be similar to running a 3.3-3.2 on a GTP engine as far as supporting mods go?
a top swapped car makes about 20 more horsepower than an L67 on the same pulley, that is if there are enough flow mods. what goes in must come out.
a 3.4 pulley is really pushing it. a ic would be best.
i had a rocker, 3.4 l67. the l36 top swap with rockers and the stock pulley would have blown the l67's doors off.
i tried the 3.4 on the top swap, i was getting tons of KR at part throttle. and im talking 1/4 throttle. 6º kr
you have a cam.
i got no real mods other then the headers and the rockers. heads are lightly ported but clearly that didnt help.
ic will be paid for on friday night :th_sinister: let the pulley dropping commence.........
Just because you saw knock, doesnt mean everyone will.
Lots of people might be able to get away without a intercooler.
This.
Im on a 2.8 with no knock on a e85 cam and genv with no intercooler i will get one before the year is over to dyno and drop to a 2.6
Sent from my LG-D851 using Tapatalk
The blue POS is on a 3.2 with roughly 9.5-10 lbs of boost with headers, and slightly ported heads and an XP. Once I figure out my fueling I'll try my 3.0 but I'd rather play it safe for now.
Now the 03 has an IC and I see blips of KR with rockers and a full size intercooler/headers, etc. about 10-12 lbs of boost.
