dbextreme
Today I was driving and my car just hiccupped then died.. No start at all afterwards. I opened the hood, hit the Schrader valve and just a little drizzle came out. I know not a good way to check fuel pressure, but I was in the middle of the road.. Towed the car home, turn key I can't hear the pump kick on like I usually can. First thought is pump is fried... concerns:
I have researched and come to this conclusion. I will be getting the 255LPH pump and install it in my car. I am still researching the venturi situation, but any of you that have insight on that would be appreciated. Since I only have one relay I assume I have to get the hot wire upgrade to bypass it all together, or will this still cause me issues??? Also pricing pumps, I see the W Body store has the 255LPH pump with the wiring harness for $129.. Is this price to good to be true? Anyone have experience with the W Body store pumps, I've heard mixed reviews? I've contacted MOAR and hopefully will hear back from him.. Racetronix is up on my list.
Regarding Venturi setups, I assume my car does NOT have a venturi pump. Is it ok to go back to non venturi is my car does not have it now, or should I upgrade? How do I upgrade my canister or can I?
I will get outside tomorrow and test some stuff to make sure it is a faulty pump, but I'm already 99% sure this is my problem..
- GT car originally with L36
- 1999 model year
- I assume the GT has the low flow LPH pump originally compared to a stock GTP
- I have XP cam with 42.5# injectors so I assume my stock high mileage pump couldn't keep up?
- I only have ONE relay, not two. I assume GTP's come with two, GT's come with one. Will this hinder me?
