took out old head unit put in new one
Status
Not open for further replies.
flipzat
i installed my deck fine it works good but when ever i turn my car off all my settings go away how do i fix this?
you didn't connect your memory wire (accesory) it should be red on the after-market wiring harness.
i did not get a harness i just cut the wires , what color is the accesory from stock deck or what can i tap into with ez
Well just cutting wires is obviously not the way to go unfortuately :( If you can piece back the wires correctly, I would recommend doing that and getting an aftermarket coupler designed to alleviate just these kind of problems you are having.
Yeah, it's about $10-15 to get an adapter and unless you know exactly what you're doing... it not only makes it easier but (usually) allows for a cleaner install.
Status
