Orange04CompG
alright so i drive an orange 2004 gtp comp g and i love it, BUT today i saw a post on craigslist where a guy is selling his 99 gtp that is metalic blue and heavily modded. i would absolutely love to mod mine,however i dont really have the monetary funds to support such endeavors! so i was wondering if you guys had any input on whether or not i should try to trade him? here is the list of mods and the bads on the 99 gtp:
also, the inside is super clean. mine isnt perfect either but its not trashed. i have custom made grille pieces that were silver and i plastidipped, i have a k&n intake, a 180 degree thermostat, a rebuilt transmission about 1000 miles ago, a new hub assembly on the front right wheel about 1000 miles ago, new both back calipers (painted red to match the other two) about 500 miles ago, a new alternator (about 2000 miles ago), and a custom gauge mount with a boost and a volt gauge. the only bad things are there is a rip in the side of the drivers seat (some jackass from an oil change place accidentally ripped it when my uncle still owned it who put the duck tape on it, i really wish he hadnt), a scratch in the paint on the front from hitting a cable at like 5 mph in the dark, and some super minor chips in the paint above the back right wheel (i tried to take a picture but they are so small it didnt show up very well).
- L26 block
- Modular Pulley System with 2.8" pulley
- Air Intake
- TOG Headers, 3" downpipe
- 160* thermostat
- Autolite 103 plugs
- Phenolic Intercooler
- Bosch intercooler pump
- ZZP large front mount heat exchanger
- #60 lbs injectors
- Previoulsy tuned for E85 by the old owner(Currently tuned for 93)
- ZZP modified fuel rails
- Ported Lower Intake Manifold
- Gen V supercharger
- Ported heads
- North Star Throttle body
- Intense Performance stage 4 blower cam
- Cam shaft supporting mods
- Kenwood stereo system.
- Bose 12 disc changer (Not Hooked up)
- Staggerd 18 inch black plasti-dipped Pontiac wheels
- TRANSMISSION:
- Fully built trans
- 3.29 gears
- 300m input shaft
- Output shaft
- Chrome Moly Pump Shaft
- Hardened 4th Clutch Shaft
- New clutch packs
- Shift kit
- 258mm 2800 stall, and more (all new gaskets, seals, bearings, dex 6 fluid)
- A/C has a slow leak and needs to be recharged
- One LED ring in the left halo head light is out, but the head lights them selves work just fine.
- Left front foglight fiberglass housing has a small hole in it on the bottom
- Paint has some small dings and nicks (Overall paint is a 7 out of 10)
