To Pulley or not to Pulley is not the question.... SIZE IS
offroad = no cat
isnt there an option for 3" DP 304 stainless with CAT?? When I was buying mine i believe the 304 stainless was another 60 or 80$ on top of the 3" w/ Cat.
Make sure you get the 02 sensor extension also. you will need that since you have an 04+ GP.
Hey, I have a 07 SC as well... know they cant tune our car so im guessin you have a 05ECM in there? If so any problems...
The questiuon I am trying to get to is I plan on keeping a CAT so do I get:
3 inch bolt in offroad
3 inch bolt in With Cat
3 inch 304 bolt in offroad
etc
I'f you are upgrading your exaust anyways, go with a new hi-flow cat, you dont want the old cat plugging up the work you did to open up your exaust
So I take I want the 3" 304 bolt in with cat vers the 3" bolt in with cat?
For the front power log if I get SS I don;t need to pick the option Ceramic coated
i wouldnt worry about the downpipe being stainless. that is going to get screwed up anyway depending upon where you live. i also wouldnt worry about ceramic coating on the stainless power log since stainless is pretty good at holding heat in by itself.
