To adjust camber.......
you need a cam bolt on whatever wheel needs the camber adjusted, or am I misunderstanding the question?
depends on if its out of spec, you need the kit. it will come with the bolts you will also need to wobble out the holes in the struts.
Camber kits all the way around is the way to go.
If you buy the right kits, you shouldn't have to drill out the holes at all, thats the whole idea behind the camber kit, to avoid doing this.
I have plenty of adjustment with mine (been running mine for 7 years now). I run Northstar camber bolts, PN: 41-958 IIRC... 2 kits will do the whole car (2 adjustable bolts in each package obviously). If you need even more adjustment buy 4 kits and replace all your knuckle bolts with camber bolts...
