Tips for removing rack and pinion
Should be 18's loosen the front up pull the rears completely. It's pretty cake it takes under and hour to man.
yeah im pretty sure it has to be dropped a bit to get access to the rack. its really not as bad as it sounds. just jack the car up as high as you can and keep the jackstands as high as you can. There should be plenty of room.
Do I need to support the engine from up top or will it stay in place with the jack under the k frame? Thanks for the replies guys this helps me alot.
