Tip: Sunroof issue fix 04+
Explicit_Spade
Perma-Banned! JK LOL
I've been having trouble with my sunroof for quite some time now. My issue was that it seemed to be getting stuck after going a short distance on the tracks. I went to the parts store inside my local "pontiac" dealer and the parts guy said its probably a $250 or so sensor that says when its open all the way.
Tonight I bought some small magnets (stong little round ones) for my license plate (that's a whole other story) and I was waiting to meet someone so I started to play with the magnets. I ran it over the dome light housing just to the top right of the crack separating the two lights (you should be able to feel the magnets pull a little bit). If it doesn't work right away, keep trying. It worked great for me.
I was just moving the magnet around until I found that spot. I didn't hit it right away becasue my problem only got slightly better at first. I then opened it while using the magnets and it opened completely in the first try. I removed the magnet and it functions now as it did when I bought the car.
Hey did your sunroof start doing this after you noticed some water leaking from there. That is what happened to me ... I guess it couldn't hurt to play with some magnets though thanks for the info.
