Timing and other numbers...
TorqueAutoMotiv
donated to get this wow
I had my scanner hooked up checking all the paramiters of the stuff it gives. Im also triing to figure out why my gas milage is so the way it is..
My priogram is a genaric so it doesnt show knock
It lists ltft,stft,timing,maf,vacuum,speed,rpms,tps,enginge temp,iat,o2 sensors,
Is there a general guidline on where the paramiters should be at idle and 2500 , and wot
Im going to go get some numbers from it and see where i am and maybe there will be some helpful info when i come back...
Thanks
All those numbers can vary so much based off the weather, elevation, throttle position, etc. We'd need to see a scan log to see how the numbers behave to really give you an idea of what's going on.
ltfts should be from -5 to 0. Never want it to be positive. 02's should be around 920 at wot. Eninge temp mine runs 185-192 depends on where I am at and outside temp.
Ok im working on geting a log that i can post just tring to figure out how to post it
I know the ltft is at a positive 3. to 5 at times
my timing during normal freeway driving is at 30* at idle it is at 20* and in boost it drops in to the low to mid teens
And my map numbers dont seem right either
Im just triing to figure out where Im suposed to be with all these numbers
I have the magnaflow too and love it, they are cheaper on ebay but I wanted a warranty(salt in winter kills an exhaust) so I got it here. magnaflow 15906, or you can try one of the vendors here, they are allways runnign sales/specials. either way its a great system and very easy to install.
LMAO
