Sabrewings
If I wanted to tighten the cradle bolts, without removing the engine/tranny, how would I support it? I thought I would put some jack stands under the cradle where the control arms are mounted, taking the engine's weight off the bolts and in fact putting the car's weight on the bushings making sure there's no gap.
The reason I ask is I've seen a half dozen cases where 04 w-bodies have slightly loose rear cradle bolts from the factory (as in, cradle never dropped or otherwise messed with). I get an occasional pop if I'm backing up an incline out of a parking space, and want to get this out of my mind.
