killswitch83
Hello everyone, I'm new here and kinda stumbled across this forum, glad to have found it too
. I have been having erratic idle issues with my '99 Grand Prix 3800 non-supercharged engine (ie will surge to 3000+ then drop hard to around 500 RPM). I pop the hood and find the vacuum connector that comes from the side of the throttle body and joins together 2 hard vacuum lines is completely split up the middle. First, what is this thing called, and second, where can I get it? I've looked on Advance Auto's site and couldn't seem to find it. I'm also thinking the IAC is beginning to cause problems too, as the erratic idle begins a short time after cranking up (2-3 minutes) though it will run fine on the road and after you first crank it up (I plan on replacing the IAC as well). Also guessing I'll need to pop off the air cleaner assy and clean out the TB while I'm at it too from what I'm seeing here......Thanks in advance everyone!
