thoughts for cam
Hawkman
just was wondering what you guys think of this cam for a supercharger setup here are the specs! thanks
[TABLE="class: tborder, width: 100%, align: center"]
[TR]
[TD="class: alt1, bgcolor: #F5F5FF"]
comp cam vsc 2002-1
intake exhaust
.512 .520
duration @ .006 tappet lift .257 .263
valve timing open close
@.050 int -7 btdc 33 abdc
exh 42 bbdc -10 atdc
specs are for cam installed @ 110.0 intake center line
intake exhaust
Duration @ .050 206 212
lobe lift .3200 .3250
lope separation 113.0
[/TD]
[/TR]
[/TABLE]
Sounds slightly smaller than an XP.
ZZP's XP page states:
Look for gains of 40-55 hp depending on your car's current configuration.
•212°/224° at .050"
•Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
•Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
•116 Lobe Separation
Edit: It is comparable to a VS
•206/216 at .050"
•Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
•Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
•115 LSA
So this will work for a supercharged application? Thanks not to familiar about cam specs yet! So any help is appreciated! So this is basically a modified cam to be similar to the vs and just has a tighter lsa? Just wanting to verify this not a n/a cam
it'll work. normally with a blower application you want a little more exhaust lift than intake lift.
Ok cool so this actually better than a vs cam than! ? Also comp 7.00. Push rods will be used with it! So this will be kinda in between cam of a vs and xp right?
Lift wise, yeah. I don't understand the rest of the specs too well myself, though to tell you the real differences.
Where did this cam come from?
Lol, not to hijack the thread, but this made me think... has anyone tried this with just a Rocker install?
Say, 1.84's Intake, 1.9's Exhaust on a stock cam?
What kinda performance gain could I expect from this cam and would a vs be a better cam to go with? The cam seems like a mix between a vs and a intense s1 cam if I'm not mistaken? Thanks
gains will be good. the difference in power between all the cams mentioned in this thread are not that much.
i think this is what ZZP does with their ER rockers.... the diff intake and exhaust rocker ratio.... the split ratio
