those running a A2A I/C and an Auxilary Tranny cooler...
fst
those running a A2A I/C and an Auxilary Tranny cooler, any fitment issues fitting the I/C around the bumper frame and the tranny cooler? :o
also anyone running a VS cam as well?
I have looked at it and did not see any issues. I will be running a Treadstone TR12 intercooler and a Transmission cooler. Just mount the Transmission cooler as close to the radiator as you can get it. Enless you plan on mounting a fan to it also. Then you can put it where ever you want.
hmm thanks, i was conerned if the charged pipes going out from the drivers side would be an issue. i have my gm auxilary trans cooler mounted long ways vertically on the drivers side to give u a better idea of where its mounted.
true, im working out payment plan a member on here for his Z7 kit (andrew_99gtp). i'll get pics once i get everything in the mail.
You can see where mine is mounted in this pic:
With my bumper support in I could not fit the trans cooler there.
also pimp prix, did u end up cutting/enlarging the hole where the 2 charged pipes go into the fenderwall?
my intercooler's bigger! NEENER NEEENEER NEEEEEENER!:th_nanana::th_peaceout:
that is where I have mine mounted, well mine is on the drivers side. I have the stock air duct cut to bring air straight to it.
