Third Brake Light 2007 GXP
nox
Does anyone have a part number for the third brake light for an '04-'08 or have an extra they'd sell? Mine is cracked to the point of not being repairable, I've hit up pick and pull, the only car they had the screws were so sun/dry rotted even trying to unscrew them caused the head to collapse. Tried a more traditional salvage yard, they refused to sell just the third lens/light and want to sell me the who deck lid.
Sent from my ASUS_Z00TD using Tapatalk
Sorry if this isn't helpful. Have you checked the FB marketplace? There was at least one GP spoiler and one whole (but cheap) rear deck on mine.
Disregard I found it.... holy crap 120 is the cheapest I've found so far....
Not sure if you are aware but the 3rd brake light is the same between the GXP and the standard spoiler.
When I got my GXP spoiler it didn't come with a 3rd brake light and when I went to remove my stock one the screw heads were stripped. I just drilled out the heads and slid the light over the now studs.
Once it was off I just used vice grips to remove what was left of the screws.
I was aware and yes A PN search I found a new one from one of the GM parts direct type sites for 120ish.... holy **** that's more than I want to spend but if I keep coming up blank ill bite the bullet. It's weird, on my car, the screws are fine, the light is cracked, at the junkyard, the lenses are fine and the screws are trashed.
That being true, some FB person posted a link to vinyls for 3rd light. http://www.grafxwerks.com/cart.php?target=product&product_id=260#product-details-tab-description
I'd imagine you'd have to contact them on this part, "You can type anything. up to like fifteen letters or something. or you can get one that says supercharged or Pontiac" ~ FB guy
Could be available on ebay? Idk, it is only a sticker.
Then take a drill and bit with you to remove the lens.
that would make sense for the simple solution. Figure out how to fasten it later.
If I take mine out again I might have to somehow break free some epoxy. really a $hitball design from the rust brained GM folks.
That would be the one place anykind of road debris hangs.
buy the worst spoiler with the best light.
or take the spoiler off in the yard so you can get at the screws better. If you can get them to spin, get a flat bar under it and it will spin out
