97AutoXVette
I have seen some conflicting arguments about thermostats, and am hoping to start a discussion on which is best and why. I know stock is 195, and obviously increasing the temp of the motor can increase efficiency (in some cases), reduce viscosity in the oil and other fluids, etc..
However, with increased heat comes increased opportunity for detonation, and higher thermal stresses, etc.
why do aftermarket manufacturers like ZZP recommend lower temp thermostats, such as a 160, even for mildly built motors?
What drawbacks are there from running lower temp thermostats on stock/mildly built motors other than maybe a slight reduction in efficiency? I would think that lower temps (within reasonable limits) would help keep the air/fuel mixture denser as well as prevent detonation? I guess the counter argument to that would be the combustion process that results may not get as hot which does not allow as much opportunity for thermal energy extraction from the fuel (possibly the loss in efficiency mentioned earlier??)
Let me know what you guys think. Open to suggestions and thoughts.
