This is actualy on my 96 Dodge B2500 w/ a 5.2 magnum. I changed the trans cooling lines (i saw fluid where the rubber was crimped onto the rest of it), and the pan gasket and washed the underside off. I started it back up and as soon as I put it back into gear, fluid starts leaking from the bell housing drain. Could this be caused by too much fluid or is it more likely an internal leak?
Thanks!
Thanks!
