The poping noise culprit is.......
QUICKSILVER462
Loose cradle bolts.
Most of the time driving slow and turning in parking lots and stuff, uneven raod surfaces going slow, and tight slow turns I would get poping noises from the front of my GTP. Turn out to be loose cradle bolts. Tightned all 4 of them, also tighned the factory braces under the hood. NO MORE NOISES!!!! YYEEAAAA!
Dean
Mine were tight still...
They're the 4 large bolts that hold your lower cradle to the subframe of your car. There are two just inside of each front tire and two up behind your front bumper. You'll need an 18mm wrench/socket to tighten them.
i have this same popping noise....and my trans was just fixed so i bet they didnt tighten the cradle bolts good enough...thanks for the info! ill check it later tonight...thought its was my motor mount but checked it yesterday and its intact....i hear the noise alot when i hit curbs in and out of driveways....
if you have poly mounts make sure the edges are lined up right those lips on the edges that stick out to fit the mount have a longer and shorter edge...i didnt realize this til reading the MSP install on 3800performance.com...fixed mine now, one was in wrong hopefully thats my popping culprit if not cradle bolts are next...
