I have been having problems starting my car after its hot and sits for 20 Min's approx, I have to press the gas peddle to get it to start and turn it over lots
what i have done so far is:
What I get when I hook up my fuel pressure gauge and the car is running is 57-58 psi but when I turn my key off it drops to 0 right away is this normal?
When I turn on the key without starting the car I can hear the pump priming but the gauge reads 0 psi till I turn it over quite a bit then the pressure climbs up to 57 psi and starts right away (again is this normal or is it not priming right? )
- changed fuel filter
- checked spark while the symptom is happening and with spark plug wire tester and it showed spark
- cleaned throttle body tore it apart
- cleaned MAF sensor it reads (g/s) 4.92 on obd2 (not sure if that is goo still learning about this)
- checked codes with obd2 scanner
- codes showed up as
- p0455 - p0128 i have a ect just have to change it my reading is 89 de C
- changed antifreeze (to prep for winter)
