wmorrison65
I just used a temp gun to read my pre/post cat temperatures. Car had been driven up to operating temperature, outside temp about 80-ish, then I let it idle about 5 minutes.
Pre-cat temp was about 380-400F. Post-cat wasn't much different. Rear should be higher, right? I measured a few other places on the pipe. On the U-bend I could read 440-450F, consistently hotter than just after the cat. (Could that be because, the restriction that forces the exhaust through the smaller-diameter pipe, "concentrates" the heat so the reading is higher?)
For the record, I also have OBD code P0137, O2 sensor circuit low voltage, bank 1, sensor 2.
I wouldn't be too disappointed if the cat is dying, as it would be a legitimate reason for a downpipe and new cat.
