Temperature Problems
spenc938
Sorry for yet another topic like this, but it's easier to get help in my own then in someone elses.
For about a month the car has had an issue where the temperature would creep up at both stop lights and lower speeds. First thing I replaced was the thermostat with another 195*. This did nothing. After this I realized that the fans weren't coming on unless the air conditioner was on, so with Sabre's advice I replaced the coolant temp sensor. Well, my fans still don't come on, and now the temperature creeps up when I am driving as well as at stop lights. The radiator is topped off, and I'm pretty sure that I have removed the air from the system. What else could be the issue? I'm thinking either a clog that happened very suddenly, or a water pump that crapped out.
I marked this as important because even with running the heater I can no longer make the long hilly drive to work, and with carpooling I miss out on about two hours a day, which is killing me.
PLEASE help.
I have checked the fuses but will check again tomorrow just to be sure.
I haven't actually flushed the system. But I blew a heater hose and took a while to find it, so I had to keep filling it back up until I did. Then I did intake manifold gaskets, and lost quite a bit there. Plus the temp sensor and thermostat were done at different times, and I lost a bunch of coolant each time.
I don't want to flush it unless I'm sure that the water pump is fine, because I'm broke and have already spent a small fortune on coolant.
personally I dont think its hard. but you might bust your nuckles a bit.
you have options get yourself a manual and have the information for life, or the autozoners should be able to show you what you need to change it on their computers.
I elect get a manual, it can help you with some other problems and possably help you with this one.
I've heard from people on this forum that the Chilton manuals suck and that the haynes is the way to go. I've been looking for a Haynes since I bought the car and stores either sell Chilton only or they don't have the Haynes for this model.
Yeah, I flushed the system, and pulled off the old pump, but it was getting cold and my hands were numb so I gave up and decided to finish tomorrow.
I also found a Haynes manual and am regretting buying it. Half the crap it says to do, I didn't need to do. Then half the crap I needed to do, it doesn't say mention. Maybe other parts of the book are better, but after reading through the water pump section a few hours before I started, I just tossed it aside and haven't opened it again.
the manual is a good refrence (sometimes). I am pretty sure they will take the book back and do a damaged return and give your money back. I keep it for wiring diagrams and such.
Sorry I haven't commented. Been out of town all week and I'm on dial up right now. Should be back home in a few days.
Personally, if the WP is good then the car needs to be scanned by someone with a tuner who can see what's going on in the PCM. The fans not turning on has me concerned. Have you tried swapping around relays? I don't know the GP's wiring off hand, but maybe one of the relays for the fans is bad (low fan) and the high relay turns on both fans. This would explain why the fans come on with the A/C but not normally.
Hope that helps.
New water pump, new coolant, and 40 degree temperatures were not enough to keep the car from overheating.
And switching around relays didn't make the fans come on either.
and @Sabre: I remember you mentioning that a warm air intake gave you better mileage... How much better was it? Was there a noticeable loss in power?
Well....when you turn the ac on do both the fans come on or just one? Just wondering if the ''low'' fan is bad and the high only comes on when the ac is on.
Both come on. If I remember correctly one does take a second or two longer than the other. (I'm thinking the driver side) I'm not sure if that matters.
Well it's not a fan issue then. Ummmm.....gotta be something with the wiring if the relays are good. did you trace all the wires?
Trace, as in checking to make sure that none of them are frayed or ripped out or anything? No I didn't.
And the fans have three relays. The two that were the same size I was able to swap. The third, I don't know about.
