Maximum Gnarnage
currently running a 3.4 pulley on the following setup and still getting 2-3* KR at the top of 2nd.
s1x cam w/ crow 105's, FSIC, headers + supporting fuel system and air intake mod's.
When I assembled and installed this motor(late on a Sunday night) I noticed the stock chain was stretched about 1 mark off and couldn't find an open parts store to replace it so I had to drop it in.
Not sure if a stretched chain could/would cause any sort of KR due to mechanical timing being off etc. But I can't help but wonder why i'm restricted to such a big pulley for my setup. AFR and timing are low 11's and 18* so i'm not being overly aggressive their.
There's a couple other symptoms that lead me to believe it could be the stretched chain. I had to bump up the idle speed and command about 13.5 afr at idle to avoid misfires. haven't heard of too many people running the s1x having to do that. car takes a couple cranks on a cold startup to turn over and fire up.
Could use some help with diagnosis to get her running strong again so speak up!
Thanks
Thanks
