I’m new on this forum, but have read here a bit and it seems like a good group.
I thought I’d share what I found with a tear-down of a very high mileage older engine, for those of you who are getting to that point, as well. All these cars are old now, but mine has an above average number of miles, so it might be a good predictor of things to look for on your engines in the future.
The car is a basically stock 2005 GTP, and has 245,000 on it now. It had developed the usual lower-end oil leaks, as well as a valve lifter noise. All this meant the engine was coming out. Here’s what I found:
The lower end is stout and well made, and probably will last forever with good oil pressure and no leaks. If you have an old engine, plan on re-sealing the entire bottom end. It was leaking from everywhere. It had seeped from the rear main for about 30,000 miles, but suddenly got bad and I knew it needed to be dealt with right away. The bores were flawless, even at this mileage, and still had nice clear cross hatching. They were left alone. The cam was shot. This was a surprise, as it’s a roller cam, but two lobes were badly pitted, and the corresponding rollers were as well. This was the source of my valvetrain noise. If you have a loud lifter click combined with a strange squeak/chirp that you can’t trace, that’s a place to look. Another surprise was the intake manifold. What I thought was the intake manifold gasket seeping turned out to be a water passage block off that was corroded right through. The manifold needed to be replaced. The exhaust cross over pipe had a crack opening up along a seam. With the heat shield off, I had it welded, then wrapped the pipe with thick header wrap. It’s better insulation than factory and keeps the throttle body much cooler.
Otherwise, everything was holding up very well. I put in a new oil pump, timing set, did a valve job with new springs and otherwise just cleaned it all up and put it back in.
