TCS OFF light is always on!
I notice my TCS OFF light is always on and I seem that I can't get it to come off I try holding the button for seconds on in but it won't shut off and it seems that I do not have any traction control on, since it can spin the tires right thru the first gear please help!
AND anyone know how I can fix my key stuck in ignition problem
This car has been nothing but headaches.......
The TCS light is likely triggered by a fault in the ABS system, usually caused by the sensor in the wheel bearing. In my case, the wire running to the bearing had somehow been sheard off.
It would help to know what year the car is as well. Do a search for "key stuck in ignition" and you should have a ton of results. Common issue.
Do you have an ABS light on as well?
