Tci transmission controller unit?
2000gtpbt
I was reading a 2006 Hot Rod magazine and after reading about then rebuilding a 305 small block I saw a ad for Tci transmission. It had a list of transmissions it works with and the 4t65e was there but when you go to the site now it's not any where. I found the unit even tho it's not on there would it still work? Dose any one have this? One transmission they list is the 4l60e witch has the same connector as the 4t65e, here's the link.
EZ TCU - Electronic Automatic Transmission Controller - TCI® Auto
Yeah it would, I was thing it's a electronic controlled transmission you could set the shift points if you changed the gears.
