Tcc pcs ????
xxburkettxx07
Diving at highway speed in overdrive car will shutter n jerk rpms go up n down a little happens in 3rd and 4th if I apply brake gently it stops, question is, is it the tcc solenoid? Should I just buy a master solenoid kit?? Any thoughts?? Please help
Galaxy S5
might be loosing 4 th gear. tapping the brakes un locks the tc and it goes back to 3 rd gear. even if your still on the gas.
Would it be a good idea to buy the master solenoid kit and the 4th hardened shaft and clutch, should that fix my problem you think ???
Galaxy S5
Also I have no check engine light I scanned it today with snap on solus ultra scanner and no transmission codes either..cleaned maf today with maf cleaner..wb tps?
Galaxy S5
Throw in a bottle of lubeguard cross your fingers and drive it like a baby until you can afford a rebuild.
hard to say, best to hit a trans shop, they got a scanner to watch the function of tranny and will know better whats up.
OK so let me relate some information I learned the hard way.
Bought a 98 Regal back in 2013, 131,015 miles and burnt fluid, bad tie rod, bad front tires, small leak at elbows (that didnt get changes till a year later). Gave $350 for it and only other issue was rusty rotors so I replaced rear pads and rotors and turned the fronts.
I swapped in a trans after old one went out after driving it around 2000 miles.
SO after much inspection and narrowing down the issue I fired up the New Solus Ultra I got in 2013. I started looking at the Brake On Off Switch(Boo).
It looked worse than a bad O2.
So give your brake switch a twist in toward the brake pedal and see if that fixes your jump 3-4/TCC lock up issue.
Good Luck
Trans is at shop getting rebuilt now, front pump went out, car wouldn't move any more. Should have trans back Friday..
Sent from my KYOCERA-C6745 using Tapatalk
