TB vacuum line thing
Skeeve
Whats the thing the vacuum lines plug into that plugs into the TB called? cause mines cracked all the way up and i need a new one. i have it taped and tie wrapped for now but i can hear air leaking.
Hey!!! good idea... :th_rockon2:
except it wont let me upload anything... pic is below all "maximum requirements" for upload
Ok i got it now..
They have a tendencie of being very brittle because of all the heat over the years. It has two lines, one leading to the EVAP purge canistor and the other leading to the fuel pressure regulator. Only way you can get another one like it is to go to the junkyard and find one. That or get one from the dealership. Broke it about 4 times on my SE before I swapped motors
Vacuum line connector? haha. If anything, just go get a vacuum tree and some rubber line. Quick fix from autozone and it'll still do its job
