Taillight blow out
jluca
My right rear tail light is dead. Probably from the condensation issue. The question i am looking for help with is this... am i going to be doing a simple bulb fix or fuse fix or am i going to be buying a whole new set up for my tail. Thanks.
i took out the tail last night to check and it was 3/4 filled with water. had problems getting the bulbs out (probably rusted in) one broke off.
Use pliers or something to get it out. I had a bulb break on me too trying to get it out, one of the small ones. So get something to grip and pull it, or to break it off more.
One of my tails fills with water and the bulb aslpoded.
just swapped the reverse light with the tail light for the time being.
new bulbs did the trick, old ones were soaked. now any ideas on how to seal this pos light up so this doesnt happen? i see a bunch of guys talking about drilling hold in the light to allow water to run out.
I masking taped mine off and put a bead of black rubberized caulking around the edges and the inside also....and drilled 2 holes in each corner of the light ...good so far
