Sway bar
BuckyKatt
So, the 1999 Grand Prix GTP appears to have one end of the front sway bar cracked. The Haynes manual indicates to replace the bar, you have to drop the subframe. Is this the case or is it possible to get the bar in/out without dropping the subframe?
Dorman has a sway bar kit that includes everything... according to the various auto part websites its a fit for the GTP... Is it really?
Thanks in advance.
BK
go here.: GM Parts Direct: Your direct source for Genuine GM Parts
and type this in at on the seach bar: 12498643
that is the sway bar, its cheap and it works.
Do you suppose that a local dealer would have it in stock at even twice that price?
Time is a factor here, the car needs to be fixed by the end of the week and will be going to live far away for a long time.
I've feeling any sway bar is better than a broken one... I'm also concerned about running into complications dropping the subframe.
You don't have to drop the subframe. It's just easier if your do. Taking out\off the old swaybar is tons easier than putting it back in.
Take off both front wheels and undo the 4 15mm bolts on top of the cradle, undo both the bolts on the A Arm. Take out sway bar, replace in opposite order. Use anti sease on the bolts on the cradle. They are a ***** otherwise.
No, GM parts direct will always be cheaper.
Thats why is says GM List price.
You dont have to drop the sub-frame to swap. Taking of one tie will make easier to install, but you do not have to drop the sub frame.
The dorman bars are a lot better than stock, yes they have a kit with new bushings links and hardware. That is how we always do them at work.
