Sway bar question
Stone 316
Hey guys, i changed my sway bar bushings awhile back along w the end links. Im tryinv to hunt down a vibration when i let off the pedal. As soon i give it throttle again the vibration goes away, anyway i noticed my end links were loose so i changed them. The passenger side end link was a pia, i had to use a long pry bar to pull it down just to start the nut. But the drivers side went on fine. Im thinking wjen i changed the bar i put it in backwards..... when im looking at the side theres a slight curve down from the bushing to the control arm, is this right?? I ran out of patience yesterday lol. Help is always appreciated here. Thanks
Front or rear? My front looks like it curves upward. You should be tightening the endlinks with the tires on the ground though. I've put the rear in upside down once, it's way harder to install and nothing lines up and it hits the mufflers.
