Suspention noise
BUTTMUNCH1
MY CAR CLUNCKS WHEN I HIT A BUMP AND IT DOESNT MATTER WHICH SIDE OF THE CAR OR WHICH WHEEL. I HAD IT CHECKED AT THE DEALER WHEN I PURCHASED IT AND THE DIDNT FIND ANYTHING. I WAS WONDERING IF THIS IS COMMON IN THE 04 GRAND PRIX OR IF THERE IS SOMETHING WRONG WITH THE SUSPENTION. THE CAR HANDLES FINE AND NO VIBRATION JUST CLUNCKING.:th_scratchhead:
My 04 gt2 rattles over small bumps and railroad tracks. Same thing nothing apparently loose and handles well. only 29000 miles on mine. It is irritating though.
same prob here with my 98 GTP , maybe its the strut mounts , cause i already checked my suspension and everything is fine , no play whatsoever ..
My 2000 GTP does that too, hahah. Car drives perfect thuogh, oh well.
My Monte is solid as a rock and drives like a wet noodle, go figure.
Dean
Thank you, it drives me nuts because i live in ohio and the roads are terrible.
Exactly!! I have a 04 compg also. I feel the same little tipping/thumping under my feet. I also live in ohio, and I do 1 hr of strret driving to and from work every morning and afternoon. I'm the guy swirving around all the bumps. Lol. Hopefully its nothiing serious.
East Liverpool is rapidly destroying my 97 GT. Had pretty much the entire front suspension rebuilt when I got the car 2 years ago and now my rear struts are leaking. I'm starting to get a bit of a thunking now too and I just figured it was from losing hydraulic fluid from the struts. You may wanna check and tighten up the bolt that holds on the spare tire/jack and see if that helps anything.
also live in ohio and the roads really do suck.
and when they finally fix them they tear it up to fix something eles.
