Kaiser Pontiac
So, I need new LCAs and probably other things on my GTP (clunks really bad stop/go). I wanted to just re-do everything necessary to get better handling, and the person I bought it from seemed like a very gas/oil/tires and go person - so I'm betting there has been minimal suspension maintenance the three years they owned it.
Anyhow, right now I just have a 33mm Dorman sway bar with new Moog poly bushings and new brackets and bolts and a rear GMPP swaybar.
So, I've been doing some reading around and I'm looking at front and rear endlinks, rear bushings, solid trailing arms, LCAs, moog k200787 problem solver control arm bushing.
Curious on recommendations on the parts I still need, and if I should get anything else.
Any difference between:
Boxed trailing arms the W-Body Store sells and the tubular ones ZZP sells
LCAs: between Moog, Dorman, W-Body store
Endlinks/rear bushings: ES and Moog
Was also looking at doing engine mounts (maybe transmission too, not sure if that's necessary?) in the future. Curious if the price for Intense's http://intense-racing.com/PROD/3800-PRO-UMMP-xxx.html is worth it over like WBS's http://www.wbodystore.com/suspension/polyurethane-engine-mounts.html. Then http://www.wbodystore.com/suspension/w-body-store-revised-engine-mount.html good?
Also, brakes, are LaCrosse Super front and rear brakes identical to GXPs? And I would assume I'll need F-body banjo bolts for front and rear, and that will be all I need in addition to the brakes? Also, for rotors, do I have to go OEM, or are there any other cheaper options that are good for the GXP brakes? Not really wanting to spend $250 on rotors, or if I just do the front $120....
Open to suggestions, what parts/brands you recommend, and really any info you have.
Thanks!
Thanks!
